The Object Details Component seems not to work with Rhino 7 (7.2.21012.11001). I referenced a bunch of points to which I have assigned an individual object name and instead of the object name displayed in the property tab the component outputs “Null”. The other outputs also deliver “Null” or “False”.
I am having the same problem, only happens with points. All other Objects show correct info when plugged into the Object Details Component.
Same thing here…
I use Human | Food4Rhino to fix it for now.
