Hi
The stitch command is not executed for subd objects and is a bug
Stitch support for subd is filed as RH-49865 which is an internal report. Check out how it works on a mesh in the Rhino 7 WIP now for an idea of what to expect once it’s implemented for subd.
Hi @BrianJ In the new version
This command only works for vertex bugs and does not work for the subd object
Stitch is having an issue on SubD… it’s back on the pile for the developers. https://mcneel.myjetbrains.com/youtrack/issue/RH-54819
thanks
Hi
This command does not work for Edge either for mesh object or subd
Rhino 7 SR0 2019-10-22
Stitch will connect two open edges… what were you expecting to happen on these interior edges?
Thanks, I see the issue now… I filed it as https://mcneel.myjetbrains.com/youtrack/issue/RH-55330
If you preselect the edges and then run Stitch it works now.
Thanks
Hi
thanks @BrianJ To fix this bug
When we run the Stitch command, its edges are sharpened, but that should not happen.
Some of its faces are gone
Hi
Some time ago I found these issue…
Hi
Thanks, there are two issues here as I see it. Filed https://mcneel.myjetbrains.com/youtrack/issue/RH-56340 for the unwanted creases and https://mcneel.myjetbrains.com/youtrack/issue/RH-56341 for holes happening from edge loop input.
Hi all
This instruction does not work when running on the edge and point…mesh!!
And sometimes it doesn’t work on the subd object
Thanks for reporting @mehran09197306634me
I filed those issues as https://mcneel.myjetbrains.com/youtrack/issue/RH-57492
