With History on:
- If I use the Copy command (or some command that makes copies), the
copies have a history relation to the parent. - If I drag the object and tap Alt, a copy is made, history is
maintained - If I drag (or rotate/scale) the object with the Gumball handle and tap Alt while
dragging, history is maintained
However if I copy (or rotate/scale) the object via an Alt+Click plus a distance entry on a Gumball handle, the history relation does not get transmitted to the copy… Methinks it should…
Thanks, --Mitch
