Bug: Hatch Behavior?
In the attached I have a shape in Red and two in Blue.
I can do a hatch on each separately.
If I do hatch on all together, it creates caca.
Problem Hatch.zip (27.9 KB)
Hi John -
I’ve put that on the list to see if that can be improved.
RH-89374 Annotation: Hatch: Region Detection Issue
The inside out rule is being confused by this configuration.
What is the expected outcome of the hatch?
Is it supposed to be completely filled?
Or are there supposed to be 3 islands of fill?
Or I guess this on could be the result:
Hatches in one command will use an inside-out rule to decide what is filled and what is not filled:
The Wall model is a series of overlapping closed objects that cannot be determined by inside out rule as it currently is written.
I thought that was obvious:
