BUG - Grasshopper Blocks - Cannot Delete - Trapped In Memory?
It appears that when I add a Model Block Instance to the Rhino Model via a Grasshopper Script even after disabling the Content Cache, deleting the block, and running the Purge Command, the InstanceObject is still trapped in “memory” and exists in the layer table despite it not existing in GH or the Block Manager.
Video Showcasing Issue:
I found this because I had a Python script that was querying InstanceDefinition UserText and it was crashing Rhino.
I traced the issue to Grasshopper keeping these “empty?” references in memory still.
Tested on 8.8 and 8.7 builds
Perhaps this is not a bug and just my limited understanding of how the InstanceDefinition Table works in scripting? Do I need to manually call a refresh or something?
My expectation would be that if Purge was ran on blocks and if all blocks have been deleted in the Rhino Model and GH model then I shouldn’t be able to “access” any of those blocks via scripting?
Example of a “lighter” error when listing blocks in the model if these undeleted “ghost blocks” are present, other errors involve User Text and Grasshopper Proxy Tables
[ERROR] FATAL UNHANDLED EXCEPTION: Python.Runtime.PythonException: 'NoneType'
Python Script For Testing:
20240609_Rhino_Grasshopper_Scripting_Conflict_01a.py (483 Bytes)
Sys Info
Rhino 8 SR8 2024-6-6 (Rhino 8, 8.8.24158.03001, Git hash:master @ c3cb4a9dc98ee25dc1f6e221e25c58a938d8d81a)
License type: Commercial, build 2024-06-06
License details: Cloud Zoo
Windows 11 (10.0.22631 SR0.0) or greater (Physical RAM: 64GB)
.NET 7.0.17
Computer platform: LAPTOP - Plugged in [99% battery remaining]
Primary display: DisplayLink USB Device (DisplayLink) Memory: 0MB, Driver date: 2-9-2024 (M-D-Y).
> External USB display device with 4 adapter port(s)
- Windows Main Display attached to adapter port 0
- Secondary monitor attached to adapter port 1
Primary OpenGL: NVIDIA GeForce RTX 3080 Ti Laptop GPU (NVidia) Memory: 16GB, Driver date: 1-15-2023 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 528.24
Secondary graphics devices.
Intel(R) Iris(R) Xe Graphics (Intel) Memory: 1GB, Driver date: 10-26-2022 (M-D-Y).
- There are no monitors attached to this device. Laptop lid is probably closed
> External USB display device with 0 adapter port(s)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 1-15-2023
Driver Version: 31.0.15.2824
Z-Buffer depth: 24 bits
Total Video Memory: 16 GB
C:\Users\micha\AppData\Roaming\McNeel\Rhinoceros\packages\8.0\Crash\1.4.2-beta\Crash.rhp “Crash” 1.4.0.0
C:\Program Files\Enscape\Enscape.Rhino.Plugin-net48\Enscape.Rhino8.Plugin.dll “Enscape.Rhino8.Plugin” 0.0.24138.1238
C:\ProgramData\McNeel\Rhinoceros\7.0\Plug-ins\Datasmith Rhino Exporter (d1fdc795-b334-4933-b680-088119cdc6bb)\DatasmithRhino7.rhp “Datasmith Exporter” 5.1.0.0
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.8.24158.3001
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.8.24158.3001
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.8.24158.3001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.8.24158.3001
C:\Program Files\Rhino 8\Plug-ins\IronPython\RhinoDLR_Python.rhp “IronPython” 8.8.24158.3001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.8.24158.3001
C:\Program Files\Rhino 8\Plug-ins\Grasshopper\GrasshopperPlugin.rhp “Grasshopper” 8.8.24158.3001
C:\Program Files\Rhino 8\Plug-ins\RhinoCode\RhinoCodePlugin.rhp “RhinoCodePlugin” 8.8.24158.3001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.8.24158.3001
Thank you for your help!
Okay after much more digging I realized this is not a bug but the way the the InstanceDefinition Table works in Rhino apparently. Nothing gets “deleted” but rather tagged as it being deleted so a “version of itself” still exists in the table despite it having no Name or info once it is “deleted”.
This was very confusing to me but I think it’s all working now. Sharing here in case anyone stumbles across this in the future.
This post solved it for me:
Example Code That Doesn’t Crash (Check If The InstanceDefinition Is Not “Deleted” First):
import Rhino
import scriptcontext as sc
def search_and_clean_block_instances():
    block_instances = sc.doc.InstanceDefinitions if hasattr(sc.doc, 'InstanceDefinitions') else []
    if block_instances:
        for instance in block_instances:
            if not instance.IsDeleted:
                # Print instance definition
                Rhino.RhinoApp.WriteLine(f"InstanceDefinition: {instance.Name} ({instance.Index})")
            else:
                Rhino.RhinoApp.WriteLine("Instance Exists In Table")
    else:
        Rhino.RhinoApp.WriteLine("No Blocks Exist")
if __name__ == "__main__":
