The following bug is present in Python 3, under Rhino 8 when using the Voronoi solver. It is not present when used in Python 2 or in GHPython.
If duplicate points are found, the solver will ignore them while issuing a warning in Python 2:
Warning: Voronoi: solver component. warning: 977 duplicate points were found. They will be ignored during the solution.
In python 3 this will trigger an exception that will stop the script and can’t be ignored:
AttributeError: 'IGH_Component' object has no attribute 'AddMessageForWarnings'
Naturally, warning messages should not stop a script. This may affect other components running in Python 3.
Attached MWE gh file
voronoi_py3_bug.gh (31.3 KB)
