For the past week or so I’ve noticed the GHPython autosolve kicking in despite being disabled. Or at least that’s what I think is happening. This occurs if I’m assigning a variable and wait a bit before typing its value, and if I’m using autocomplete and wait a bit before typing after using the dot completion. Here’s a quick example demonstrating this behaviour (leading to errors in both cases):
Best,
Anders
Update: This is running Rhino version (7.8.21174.15001, 2021-06-23)
That isn’t autosolve. We attempt to “compile” the script on a timed basis to report any potential compilation errors. We’ve had that in there for quite a while. What kinds of problems is it causing?
Ah yes, I see the difference now. This feature doesn’t actually run the code. My bad.
We only recently upgraded to Rhino 7 and I must have missed this new feature/behaviour until now.
I depend on the output panel when developing and debugging. And the information that’s printed to it disappears when this new feature kicks in while I’m typing something. Which needless to say messes quite severely with my coding loop.
I also personally prefer “things not to do things” unless I tell them to, and find operating under a timer stressful (i.e. you have X seconds to do something before something happens). But I certainly see why others would find this feature useful.
Update: Here’s a demonstration of the former issue above, along with a new one I just noticed. The error message printed by this new “compile test feature” doesn’t go away after the potential syntax “error” is “corrected” (at ~20 seconds in):
