Bizarre display for objects that are over a white background image with no transparency - that may be used for sketching or point adjusting - in ghosted mode.
With backface color equals front face color (default setting) : this is fine.
Please post your example 3dm file, export your modified Ghosted display mode and post the resulting Ghosted.ini file too.
Also, run the Rhino SystemInfo command and post those results.
Then maybe we can repeat the issue and have enough detail to figure out what’s going wrong.
