Hi All,
Tried to explode Text Entity in GH and got font changed.
With some fonts works, some not.
In Rhino itself the explosion works correctly.
Any workaround?
Hi @Screamer,
Can you upload a .GH file with the text internalized?
What version of Rhino do you use?
Thanks,
ā Dale
Hi @dale ,
Sure, sorry for not doing it from the beginning.
Latest V8 Rhino.
TextExplode.gh (17.5 KB)
@AndyPayne - is this something you could help with?
Hi @Screamer,
This will be fixed on v8.31.
Thanks for reporting.
great this gets update, was strungleing with this as well today (looked like a weird offset, turns out defaulted to another font
@Screamer , since it works within rhino, we can use this as temp fix for now i suppose, seems to work for me:
import Rhino
import Grasshopper as gh
# Input: text_input (Tree Access, Type Hint: TextEntity)
# Output: curve_output
curve_output = gh.DataTree[Rhino.Geometry.Curve]()
if text_input is not None:
for i in range(text_input.BranchCount):
path = text_input.Path(i)
branch = text_input.Branch(i)
for j, text_entity in enumerate(branch):
if text_entity is not None:
curves = text_entity.Explode()
if curves:
new_path = path.AppendElement(j)
curve_output.AddRange(curves, new_path)
