When referencing an element (in this case ‘‘Generic model’’) that has been cut with a void, the component reads the geometry as it was before it got cut with the void.
Example: I selected two faces in Revit, and when connecting them to the Surface-component in GH I get the original surface without the cut from the void.
Hey @lindgren.eirik
I tested this on a wall that has the base attached to a floor, and a Generic model-in-place components that has voids and both work fine. Would you mind sending me a test model or describe how to generate the model that has the issue?
