[BUG FOUND] - Lost block data causes all drawing information to be lost
I’ve been struggling with this issue all morning. I am using the Rhino 9 WIP version 9.0.26167.11545, 2026-06-16.
I have a file that was semi-corrupted, specifically there were drawn line-work blocks in the file that I’ve exploded and then copied over to a new fresh file. For clarity, in the new file, they have been brought in as individual line segments/open curves. When I edit any block, the block editor greys all elements not included in the block per usual. However, when I finish editing the block, all of the linework that was included in the original blocks that have been copied over and exploded remains uneditable and greyed out as if I was still in the block editor.
562_ISSUE.3dm (10.1 MB)
Hi Maxwell -
I’m having a hard time understanding the steps that are taken here.
Is this something I should be able to reproduce in the file that you attached? As you noted, that file doesn’t contain blocks, so I would have to turn some geometry into blocks first?
Hi Maxwell,
I take it you mean the floorplans. You cannot access them because they are locked. To free all of them, run the _Unlock command. If you only want to unlock selected parts, run _UnlockSelected and then select the ones you want unlocked.
HTH
Jeremy
