Bug Fillet?
The attached file contains curves generated by MAKE2D.
If I try FILLET (Radius=0) near the common ends of the red curves, I get the blue curve.
Problem Fillet.3dm.zip (19.6 KB)
Hello - SimplifyCrv will let this work (Connect or Fillet at zero) The lower segment has stacked control points at the right hand end.
I had actually run simplycrv on the entire MAKE2D output.
