Bug: Fillet Corners
I want to do a fillet of 0,1cm (unit is set to cm) - but it would make a fillet of 1cm so ten times bigger. Do I miss something? thank you!
hi @hannesgrebinwork
pls send a sample that shows this behavior, as I cannot repeat this here.
You created this other topic where the dimensions were ten times bigger than expected…
Could be related?
PS: How do you create the screen video? Is there a particular reason you upload everything to YouTube instead of uploading an mp4 directly into a post?
Thanks Martin, that is most likely the issue.
Just to add to @martinsiegrist post: videos can be helpful sometimes but best is to first send a simple file that illustrates the issue.
