I noticed that “Global edge continuity” has some issues with reporting correct numbers in areas where the adjacent surfaces lay on a very close gap. The attached file consists a surface that’s matched over another surface.
The only way to force a complete and proper report from “Global edge continuity” is to extend the large target surface by at least 1 millimeter, in order to move its edge away from the nearby edge of the matched surface. Only then the GEC analysis fills the entire length of the edge (edge number 5 in the video).
You will notice that when I extended the surface by about 0,5 mm, the GEC analysis actually got shorter for no obvious reason. However, as soon as I extended the surface again, the analysis covered the entire edge.
Is it possible to fix this issue, so that the user will not be forced to extend the target surface (or make a copy of it to extend) just to be able to see the complete GEC analysis?
The G0 filter is set to 1 mm, because the default lower number didn’t detect many of the adjacent edges that I typically match manually where the automated “Match surface” fails. A value of 0,36 is the largest one that fills the entire edge with the hair analysis. Any number larger than 0,37 cuts the analysis.
Thanks for adding this to the pile! In cases where the majority of the edge matched on the surface is far from the edge of the latter, it should prioritize the target surface instead of its edge. Perhaps a threshold of 50% (edge length VS surface length) would help.
