Hi guys,
I work with linked files, but I run into issues when trying to extract their rendermeshes. They dupliacte OK, but are not transfered to the host file and I can not UNDO the extraction nor handle those meshes. The extracted rendermeshes are still stuck in / linked to the inserted file for some reason.
Example:
make a file with a box and save.
make a new file and insert the box-file and select it and extract render mesh.
Now try to move the extracted rendermesh or undo the extraction and you should see the problem.
Thanks
Edit:
Even if I undo everything done in the host file (even the insertion of the box file) I can still see the extracted mesh that won’t undo. I can pick it and try to drag it, but it snaps back to where the file would have been inserted.
