When I use Export command in Layout view, the export dialog box does not show format and other options. Unless I resize the dialog box, then it appears. Video and SystemInfo below. Using Export in design view works fine.
systeminfo.txt (5.5 KB)
Hello- thanks, this one has been fixed -
RH-61670 Export: Options are not visible from layout page unless dialog is resized
