I am having trouble exporting a parent block containing a child block. The nested child block is not visible/present in the exported parent DWG.
Rhino file containing a block PARENT
containing a CHILD
Block together with various geometries.
Using the BlockManager
, select the PARENT
block, click Export
. and used the scheme attached.
The result Parent.DWG does not contain the CHILD block.
Is the geometry/structure too complex ? Any ideas ?
BlockExportBug_Sample.zip (49.9 KB) attached containing the following:
- Rhino .3dm file
- AutoCAD export scheme
- Exported DWG’s
OS: Win7 x64, Rhino5 SR8.
