BUG : Edit Dimensions in layouts crashes Rhino
In an empty file, if you create a layout and place a dimension on it and then want to edit it as you would anywhere else in rhino using the grips, Rhino crashes.
It also looks like history auto-update of dimensions attached to objects in the detail has been broken.
Latest WIP 8.0.23186.12306, on macOS Intel
I was able replicate & get a crash report and will get a bug report starting.
Thanks for reporting.
Same problem on Windows, latest WIP. Crash in layout (not empty)
