Bug: DraftAngleAnalysis pull direction sometimes flips during EndBulge
The bug described below exists in:
  • 7 SR38
  • 8.35.26251.13001, 2026-09-08
  • BETA (9.0.26258.12303, 9/15/2026)
EndBulge_with_DraftAngleAnalysis.3dm (97.1 KB) contains a surface and 3 copies of it, each in a different position and orientation.
When the orientation of each face matches its underlying surface’s normal (OrientationIsReversed = false), and _EndBulge is applied to the lowest edge (completely in -Z) of each,
the _DraftAngleAnalysis display changes as if the pull direction was flipped on (just) the 2 inner surfaces during the point-dragging part of the command. (The images below show one example of this.)
When the orientation of each face is opposite of its underlying surface’s normal (OrientationIsReversed = true), and _EndBulge is applied to the lower edge of each,
the _DraftAngleAnalysis display changes as if the pull direction was flipped on (just) the 2 outer surfaces during the point-dragging part of the command.
With no command running and OrientationIsReversed = false:
With _EndBulge active on one surface with OrientationIsReversed = false:
Hi @spb,
I am investigating - thanks,
– Dale
RH-98840 is fixed in Rhino BETA
