I sya a bug with the “_divideAlongCreases” commande
with the object
if i select this object and i run the “_divideAlongCreases” commande then the command didn’t print the option.
if i unselect all object and i run the “_divideAlongCreases” commande then the commande run correctly
do you see this bug
you can see the attache file.
Bug Dividealong.3dm (74.8 KB)
best regards
