BUG: Dimension Selection
A)
If I select a group of linear dimensions, I can collectively change the annotation style.
If I then add an angular or radial dimension to the selection, I can no longer change the annotation style.
B)
If do Select Annotation Style, I can collectively change the annotation style UNLESS there is a mixture of dimension types.
It seems to me that, I should be able to change the annotation style in these cases.
This is a known issue that is indeed inconvenient. It is logged here.
In the meantime you can quickly select all the annotations a group at a time and change their style using commands like:
SelDimLinear
SelDimAngular
SelDimOrdinate
SelDimRadial
Thanks for the feedback
