BUG Dimension minimum line weight in PDF is 0.25?
It appears that the line weight of dimensions in a printed PDF can’t be thinner than 0,25.
The video below should demonstrate this:
What I’m doing there:
Experiment 1: Dim set to 0.25, line set to 0.13
The result is that the dim appears thicker than the line — which is the expected result
Experiment 2: Dim set to 0.13, line set to 0.25
Dim and line have the same thickness in PDF.
Is this a bug, or am I missing something? @Gijs, can you help?
Rhino 8 SR10 2024-7-30 (Rhino 8, 8.10.24212.13001, Git hash:master @ bf71fa5917a747cb0d08481b3fcbd3bce0923e77)
License type: Commercial, build 2024-07-30
License details: Cloud Zoo
Windows 11 (10.0.22631 SR0.0) or greater (Physical RAM: 32GB)
.NET 7.0.20
Computer platform: LAPTOP - Plugged in [80% battery remaining]
Primary display: Intel(R) Iris(R) Xe Graphics (Intel) Memory: 1GB, Driver date: 6-15-2023 (M-D-Y).
Primary OpenGL: NVIDIA GeForce RTX 4070 Laptop GPU (NVidia) Memory: 8GB, Driver date: 6-25-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 556.12
OpenGL Settings
Safe mode: Off
Anti-alias mode: 8x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 6-25-2024
Driver Version: 32.0.15.5612
Z-Buffer depth: 24 bits
Total Video Memory: 8188 MB
C:\Program Files\Chaos Group\V-Ray\V-Ray for Rhinoceros\V7\VRayForRhino.rhp “V-Ray for Rhino”
C:\Users\simon\AppData\Roaming\McNeel\Rhinoceros\packages\8.0\NVIDIADenoiser\0.4.3\NVIDIADenoiser.Windows.rhp “NVIDIADenoiser.Windows” 0.4.3.0
C:\Users\simon\AppData\Roaming\McNeel\Rhinoceros\packages\8.0\Bullant\23.10.24.0\bullant.rhp “bullant” 23.10.24.0
C:\Users\simon\AppData\Roaming\McNeel\Rhinoceros\packages\8.0\ggRhinoIFC\24.7.27.8\ggRhinoIFC.rhp “ggRhinoIFC” 24.7.27.8
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.10.24212.13001
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.10.24212.13001
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.10.24212.13001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.10.24212.13001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.10.24212.13001
C:\Program Files\Rhino 8\Plug-ins\export_PDF.rhp “PDF Export” 8.10.24212.13001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.10.24212.13001
Dim_Min_Print-Width.3dm (67.7 KB)
Dim_Min_Print-Width_01.pdf (21.1 KB)
Dim_Min_Print-Width_02.pdf (21.1 KB)
Looking into this I am seeing that the dimensions set through linetypes don’t work correctly for dimensions.
I don’t see that the minimum linewidth is 0.25 though.
RH-83328 Print widths don’t work correctly for dimensions
I have the same problem. Rhino 8 introduced a lot of scaling and display bugs with linetypes, linewidths and annotations which is very frustrating as these are essential for architectural drawings.
Hi -
Please make sure to provide details and 3dm files so that these issues can be looked into.
Sorry for not providing details before, but the problem was fixed so thank you a lot!
There is still a small part of the bug persisting:
In leaders, if you have a landing it defaults to some line width and not respecting the thinner line width. Here are some files and details for it.
A4 (no landing).pdf (21.5 KB)
A4.pdf (21.5 KB)
Leader with landing.3dm (43.7 KB)
For now I will just remove the landing from my leaders, so no biggie.
Kind regards,
Keskinen
Thanks.
RH-84094 Annotation: Linetype: Leader
RH-84094 is fixed in Rhino 8 Service Release 13
