Rhino 8 SR13 2024-11-6 (Rhino 8, 8.13.24311.03001
just moving a value in dimension inside layout (one dimension point is geometry point inside detail view the other is from geometry on layout) breaks it.
Hi Ivan -
If I understand the workflow correctly, the 5.7 should have become 58.3 in the following example:
Can you post a 3dm file where such behavior happens?
sent the file to support email.
Hi Ivan -
Thanks.
It looks like I might need instructions as well…
there is already the new dimension where i used some other method (workaround clicking two points from the detailview).
make new dimension like this:
there is axis line drawn on layout so near snap to that axis line
Hi Ivan -
Thanks. It looks like this only happens in a detail that is clipped.
→ RH-84750 History: Dim on Model Section and Paper Update Issue
your only is my always (because i use clipped views all the time)
RH-84750 is fixed in Rhino 8 Service Release 15
