Bug ? Custom display mode, shadow intensity is not saved
I’ve duplicated a Technical display mode and attempt to change the shadow intensity plus some other settings like line thickness.
Aside from the fact that the percentage window is too small, this setting is reset to 0 when the options are reopened.
But it works if the language is set to English !
I’m suspecting a weird behaviour where the longer label in French reduces the text box size that is therefore too small to contain a two-digit number ?
Hello - thanks, I’ll check this.
Got it, thenks.
RH-75209 Display modes: cannot change the shadow intensity
Thanks, I see this is fixed in the latest WIP.
