[Bug?] Curve | Self component misses intersections
The Curve | Self component misses self-intersections.
I have to self-intersect curves multiple times to make sure that I obtain all of the intersections, which is weird to me.
Self-intersecting.gh (9.7 KB)
Version 8 SR31 (8.31.26126.13431, 2026-05-06), Windows 11.
As far I know (and please correct me if I am wrong). Curve | Self only show the points where the curve intersects (crossing curves) and not where the curve touches itself. Compare for example with a rectangle, also a polyline, what gives 0 intersections with itself.
For what you need, probably explode + cull list (to cull a couple of double sections) is the fastest way to go.
Regards, Eef
Thing is if I test for self-intersection for a segment, it’ll show new intersection points.
To show the curve structure, I moved two of the vertices to the right:
The segments are overlapping.
Even polyline reduction doesn’t change this problem:
Self-intersecting.gh (24.1 KB)
The self-intersection just doesn’t seem to be recursive.
