Hi @kike and @andyopayne,
I trigged a âfreezeâ or rather VERY slow behavior I am calling a freeze.
To repeat:
-Cache a larger number of geometry objects such as 1,400
-Have the Model Object node use a referenced Model Material for itâs Render Material
-Ensure this is in a blank document where this material does not yet exist in Rhino
-Leave the Grasshopper script running and attempt, in Rhino, to create a new material that matches this Query Model Material name input.
-Rhino/GH will slow to the point of freezing and a green loading bar appears under the Content Cache component and sloooowly progresses.
Some imagery below:
Grasshopper, note that âSatin Copperâ is referenced as the Name input for Query Model Material but does not exist in the Rhino Document yet.
30 min later:
Script solver is active.
Created a new material of type âMetalâ and named to âSatin Copperâ, note that the screen snip here is what Rhino is frozen on after committing the name change to Satin Copper:
Grasshopper/Rhino freezes, green loading bar shows up under Cache component and it does progress but a bout 1% a minute and RAM usage of Rhino jumps to 54% in task manager.
System Info
Rhino 8 SR19 2025-4-22 (Rhino 8, 8.19.25112.13001, Git hash:master @ 0fe5f551e3e34ca51834ba0ca2217647d8027942)
License type: Commercial, build 2025-04-22
License details: Cloud Zoo
Windows 11 (10.0.26100 SR0.0) or greater (Physical RAM: 64GB)
.NET 7.0.20
Computer platform: LAPTOP - Plugged in [98% battery remaining]
Primary display: DisplayLink USB Device (DisplayLink) Memory: 0MB, Driver date: 12-18-2024 (M-D-Y).
> External USB display device with 4 adapter port(s)
- Windows Main Display attached to adapter port 0
Primary OpenGL: NVIDIA GeForce RTX 3080 Ti Laptop GPU (NVidia) Memory: 16GB, Driver date: 11-6-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 566.14
Secondary graphics devices.
Intel(R) Iris(R) Xe Graphics (Intel) Memory: 1GB, Driver date: 10-26-2022 (M-D-Y).
- There are no monitors attached to this device. Laptop lid is probably closed
> External USB display device with 0 adapter port(s)
OpenGL Settings
Safe mode: Off
GPU Tessellation is: On
Redraw scene when viewports are exposed: Off
Graphics level being used: OpenGL 4.6 (primary GPUâs maximum)
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 11-6-2024
Driver Version: 32.0.15.6614
Z-Buffer depth: 24 bits
Total Video Memory: 16 GB
C:\ProgramData\McNeel\Rhinoceros\7.0\Plug-ins\Datasmith Rhino Exporter (d1fdc795-b334-4933-b680-088119cdc6bb)\DatasmithRhino7.rhp âDatasmith Exporterâ 5.1.0.0
C:\Program Files\Enscape\Enscape.Rhino.Plugin-net48\Enscape.Rhino8.Plugin.dll âEnscape.Rhino8.Pluginâ 4.2.1.88
C:\Users\micha\AppData\Roaming\McNeel\Rhinoceros\packages\8.0\Crash\1.4.2-beta\Crash.rhp âCrashâ 1.4.0.0
C:\Users\micha\AppData\Roaming\McNeel\Rhinoceros\8.0\Plug-ins\D5LiveSync (e0d5e210-02f6-4ee9-a2b0-1675e225d958)\D5Conv.rhp âD5 Live Sync for Rhinoâ
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp âCommandsâ 8.19.25112.13001
C:\Program Files\Rhino 8\Plug-ins\rdk.rhp âRenderer Development Kitâ
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp âRhino Renderâ 8.19.25112.13001
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp âRDK_EtoUIâ 8.19.25112.13001
C:\Program Files\Rhino 8\Plug-ins\NamedSnapshots.rhp âSnapshotsâ
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp âMeshCommandsâ 8.19.25112.13001
C:\Program Files\Rhino 8\Plug-ins\IronPython\RhinoDLR_Python.rhp âIronPythonâ 8.19.25112.13001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp âRhinoCyclesâ 8.19.25112.13001
C:\Program Files\Rhino 8\Plug-ins\Grasshopper\GrasshopperPlugin.rhp âGrasshopperâ 8.19.25112.13001
C:\Program Files\Rhino 8\Plug-ins\RhinoCode\RhinoCodePlugin.rhp âRhinoCodePluginâ 8.19.25112.13001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp âToolbarsâ 8.19.25112.13001
C:\Program Files\Rhino 8\Plug-ins\3dxrhino.rhp â3Dconnexion 3D Mouseâ
C:\Program Files\Rhino 8\Plug-ins\Displacement.rhp âDisplacementâ
C:\Program Files\Rhino 8\Plug-ins\SectionTools.rhp âSectionToolsâ
Thank you all!
