Bug: Content Cache messes up Object Display Mode
If you push objects with a display mode override, it does not allow you to change the display mode back to ‘By View’ in Rhino.
content_cache_display_mode_bug.gh (11.4 KB)
I am using Version 8 SR33
(8.33.26188.13001, 2026-07-07)
Hi Kyuubimode,
Thanks for reporting — i was able to track down what’s going on.
The display mode that Model Object / Content Cache applies is an “all viewports” override, but the Properties panel dropdown only knows how to remove per-viewport overrides. It can see the all-viewports one (that’s why it shows the mode) but By View can’t remove it, so it snaps right back.
Until this is fixed, the ClearAllObjectDisplayModes command will clear it — select the objects and run it, display goes back to By View.
Filed: RH-96944 Properties panel “By View” cannot remove an all-viewports display mode override
RH-96944 is fixed in Rhino 8 Service Release 35
