Bug: commands 'PopupMenu' and 'PopupPopular' don't show anything
Running ‘_PopupMenu’ works in 8 i have on an alias, to show the most recent commands. In rhino 9 i have never had it appear once. It doesnt work when running it manually either btw. ‘PopupMenu’ no errors, just doesnt appear.
These are re the options related to it, right?
‘PopupPopular’ also doesn’t seem to work. (and also was fine in 8).
by holding down the middle mouse button for a while and getting the little menu, then letting go the menu does pop up.
In the options->mouse menu ticking off ‘manipulate view’ ofc makes that menu appear instantly, but it does not appear when calling the command(which is the way i use it).
can anyone else try/replicate this, or see if its just on my setup?
I don’t know these two commands well enough to properly check the issue myself.
I found this related ticket that might be connected:
(PopupToolbar was not fully migrated to the new system in Rhino 9)
Can anyone else try/replicate this, or see if its just on his setup?
aha! ye that might be it. the funny thing is just that, by holding middle mouse button and having settings → mouse set to this
it does pop up, but calling the command (which should do the same thing) does not.
@Japhy hey is this related? i tested today, on Version 9.0.26237.15343 (2026-08-25)and _PopupMenudoesn’t work. (or is https://mcneel.myjetbrains.com/youtrack/issue/RH-95188 another issue?)
