that is not acceptable, i am not going to buy Rhino 8 just to be able to use the command history again!! common guys really not.
and no dont suggest us to spend a day to role back the mac os version. please fix that for 7 either.
Yes - I agree.
I know I am beating a dead horse, but here we go:
I asked John if this can be prioritized
Its better, but still easy to break:
for(int i = 0; i < 100; i++) {
RhinoApp.WriteLine("Test: " + i.ToString());
After running this a few times it scrolls only halfway or more, but never to the end. And does not recover. Dragging a box etc. results in erratic jumping around. Once the Buffer is is full (around 4k lines) it stablizies a bit, but still:
What i see:
what it is:
Edit:
I don’t think my script has anything specifically to do with it, so i assume it would fail after an hour of work… Also for the screenshots i removed the panel from the dock, this makes no difference.
Same for the bottom panel:
@atair I could not reproduce the behavior your are seeing. I only get a slight issue in the panel, when printing to the commandline with a script, see YT report.
FYI I tested this in 14.0 Sonoma on an intel Mac
I am still on 13, and just tested again without any scipts - just repeat command about 30 times (pressing enter over and over):
what i get
what is should be:
fresh file, didnt touch anything else
@atair I asked if someone else here can repeat, I tried again but cannot.
@dan could not reproduce either on a mac M1 on Sonoma. Do you plan upgrading to Sonoma as well @atair and see if this resolves things for you?
eventually - but because of Rhino / unity - xcode etc I wait a few more weeks… lets see if someone else can reproduce it in the meantime
Version 8 BETA (8.0.23271.13234, 2023-09-28)
Expires November 12, 2023
mac os x 13.5.1 (22G90)
I can confirm that the scroll behaviour of the command line still is buggy.
(sorry - and thanks for the effort)
i m doing some scrolling in the video with the trackpad - which is not really visible on the screen capture…(the magic movements are trackpad-scrolling)
scrolling to the top will make the panel stuck to this position.
Hi @atair,
We have this already logged, fixed and tested::RH-73417 - CommandHistory-doesnt-scroll-to-the-bottom
Looks like it has been tested and will be available in the next BETA.
You will be notified here when it is in the next Rhino 8 Beta build and it is ready for you to test out…
Thanks, ,
Mary Ann Fugier
sorry but this is still fundamentally broken - after 30-40 commands it does not scroll anymore. Even before it catches up sometimes only after 1-2 commands.
@mary
bumping this for visibility…
Just updated MacOS to Sonoma, now I have this bug too.
today i finally switched to Rhino 8 - its still not scrolling to the end. On YouTrack you write it seems to work in normal operation, but it does not unfortunately.
Select and move something around 10+ times and it will start to lag behind.
It looks like this is marked as resolved, but it is not.
Hi @atair pls run _SystemInfo and post back the results. Then I can add the info to the yt and reopen it. Thanks.
Hi - one thing:
It is not easy to trigger this - it now took me about 100 drag/select/shade commands till it started shifting… it might be when the buffer is full or something to to with multiline outputs (e.g. shaded/wireframe) - but in any case - it takes a bit to break it.
here the data:
Rhino 8 SR5 2024-3-12 (Rhino 8, 8.5.24072.13002, Git hash:master @ e3530849b75f00b2b977766a567ae29b055837e9)
License type: Educational, build 2024-03-12
License details: Cloud Zoo
Apple macOS Version 13.5.2 (Build 22G91) (Physical RAM: 32GB)
Mac Model Identifier: MacBookPro18,2
Language: en-AT (MacOS default)
.NET 7.0.0
Metal GPU Family Apple 7
Metal GPU Family Common 3
Metal GPU Family Mac 2
Graphics processors
Apple M1 Max
Color LCD (1728 x 1117 @ 120.00Hz)
USB devices
GenesysLogic: USB3.1 Hub
Hewlett-Packard: HP LaserJet Professional P 1102w
Logitech: USB Receiver
USB C : USB C Video Adaptor
Apple Inc.: iPad
Bluetooth devices
None
Third party kernel extensions
None
Third party plugins
/usr/lib/usd/libIex.dylib
/usr/lib/usd/libHalf.dylib
/usr/lib/usd/libAlembic.dylib
/usr/lib/usd/libusd_ms.dylib
/usr/lib/usd/libosdCPU.dylib
/usr/lib/usd/libImath.dylib
/usr/lib/usd/libIlmThread.dylib
/usr/lib/usd/libIexMath.dylib
/usr/lib/usd/libtbb.dylib
/usr/lib/usd/libMaterialXCore.dylib
/usr/lib/usd/libMaterialXFormat.dylib
/usr/lib/swift/libswiftNetwork.dylib
/usr/lib/swift/libswiftAppKit.dylib
/usr/lib/swift/libswiftFileProvider.dylib
/usr/lib/swift/libswiftPrivate_BiomePubSub.dylib
/usr/lib/swift/libswiftPrivate_BiomeStreams.dylib
/usr/lib/swift/libswiftExtensionFoundation.dylib
/usr/lib/swift/libswiftCoreML.dylib
/usr/lib/swift/libswiftVision.dylib
/usr/lib/swift/libswiftExtensionKit.dylib
/usr/lib/swift/libswiftWebKit.dylib
/usr/lib/swift/libswiftGLKit.dylib
/usr/lib/swift/libswiftMapKit.dylib
/usr/lib/swift/libswiftModelIO.dylib
/usr/lib/swift/libswiftSceneKit.dylib
/Applications/Rhino 8.app/Contents/Frameworks/RhMaterialEditor.framework "Renderer Development Kit" 8.5.24072.1002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Commands.rhp "Commands" 8.5.24072.13002
/Applications/Rhino 8.app/Contents/PlugIns/NamedSnapshots.rhp "Snapshots" 8.5.24072.1002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RDK_EtoUI.rhp "RDK_EtoUI" 8.5.24072.13002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/MeshCommands.rhp "MeshCommands" 8.5.24072.13002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoRenderCycles.rhp "Rhino Render" 8.5.24072.13002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCycles.rhp "RhinoCycles" 8.5.24072.13002
/Applications/Rhino 8.app/Contents/PlugIns/SectionTools.rhp "SectionTools" 8.5.24072.1002
/Applications/Rhino 8.app/Contents/PlugIns/Displacement.rhp "Displacement" 8.5.24072.1002
/Applications/Rhino 8.app/Contents/PlugIns/PanelingTools.rhp "PanelingTools" 8.5.24072.1002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoDLR_Python.rhp "IronPython" 8.5.24072.13002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/GrasshopperPlugin.rhp "Grasshopper" 8.5.24072.13002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCodePlugin.rhp "RhinoCodePlugin" 8.5.24072.13002
…and once it jumps, its shifted by 10+ lines - so quite a lot
Also the error only seems to show when the panel/window is docked… i didnt manage to break it when a floating window… (till now)
