Bug Clipping Drawings
Hi, i used the ClippingSections command and placed the section with the ClippingDrawings command. Unfortunately, not all hidden edges are displayed with the hidden layer. The hidden edges should actually all be dashed. Both images are in the same section.
I Michael,
Can you post your systemInfo (run SystemInfo in the Rhino command line) and a small file example file? Thanks
SystemInfo.txt (2.5 KB)
A couple things jump out…
Rhino and video drivers could use updates
Rhino 8.7.24138.15431
NVIDIA Quadro P400 (NVidia) Memory: 2GB, Driver date: 5-22-2019 (M-D-Y). OpenGL Ver: 4.6.0
