8.16.25042.13001, 2025-02-11
This occurs with various modeless dialogs and various panels for that particular type of panel button. For example, the larger buttons at the top of the Properties panel do not do this.
Hi Steven, I’m not able to repeat in a newer internal build (8.18), hopefully its fixed. If no one else chimes in i will load 8.16 later today and try again.
Can you run the systemInfo command and post the results? Thanks
