Bug: cant set the range higher than 500
Hi there, i want to render a set of frames but i cant fill in higher than 500,…
I’m not able to reproduce this problem.
What version of Bongo are you using?
(Type in BongoAbout on the timeline and it should give you a date)
What version Rhino are you using?
(Type in About on the timeline and it should give you a date)
Can you please send a screenshot of your settings in the dialog box?
bongo 14-11-2014
and rhino 1-12-2014
