…in Options>Files>Template files
Hi H- I see that… it’s always been so, I think… I am not sure why. I’ll see if I can find out if there is a good reason, neither of my brain cells is coming up with it right now,
IIRC you can specify the template folder, but the default template file is something you select using the UI in Rhino, and it needs to be in the default template folder. I know this decision was made intentionally, but the rationale has left my mind, too.
I hope we will avoid internet shortcut language as much as possible.
ROTFLMAO
IMHO, [quote=“brian, post:5, topic:291”]
ROTFLMAO
[/quote]
IMHO, ROTFLMAO is the SQN of PIA.
