BUG: Can't change section in the Document Properties window
After yesterday’s Rhino 8 Release Candidate and Rhino WIP update I can’t change sections in the Document Properties window. Double checked by reinstalling.
Rhino 8.13.24317 - OK
Rhino 8.14.24317 - Broken
Rhino WIP 9.0.24317 - Broken
System Info
Rhino 8 SR14 2024-11-12 (Rhino 8, 8.14.24317.14001, Git hash:master @ 69ab12ed53cf1e6d17f23ab5fec3c3f7216df72d)
License type: Educational, build 2024-11-12
License details: Cloud Zoo
Windows 11 (10.0.22631 SR0.0) or greater (Physical RAM: 64GB)
.NET 8.0.10
Primary display and OpenGL: NVIDIA RTX A3000 12GB Laptop GPU (NVidia) Memory: 11GB, Driver date: 6-10-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 538.78
Primary OpenGL: NVIDIA RTX A3000 12GB Laptop GPU (NVidia) Memory: 11GB, Driver date: 6-10-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 538.78
Secondary graphics devices.
Intel(R) UHD Graphics (Intel) Memory: 128MB, Driver date: 4-2-2024 (M-D-Y).
OpenGL Settings
Safe mode: Off
GPU Tessellation is: Off
Anti-alias mode: 8x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 6-10-2024
Driver Version: 31.0.15.3878
Z-Buffer depth: 24 bits
Total Video Memory: 11520 MB
C:\Program Files\Rhino 8\Plug-ins\RhinoToGrasshopper\RhinoToGrasshopper.rhp “RhinoToGrasshopper” 1.0.0.0
C:\Users\Czaja\AppData\Roaming\McNeel\Rhinoceros\packages\8.0\Synapse\0.4.0\SynapseRCP.rhp “SynapseRCP” 0.4.0.0
C:\Users\Czaja\AppData\Roaming\McNeel\Rhinoceros\8.0\Plug-ins\Bella (813de3fb-18eb-405f-bfcd-b0b4d3da91fb)\24.2.0.0\bella_rhino.rhp “Bella” 24.2.0.0
C:\Users\Czaja\AppData\Roaming\McNeel\Rhinoceros\packages\8.0\Crash\1.4.2-beta\Crash.rhp “Crash” 1.4.0.0
C:\Users\Czaja\AppData\Roaming\McNeel\Rhinoceros\8.0\Plug-ins\Crayon (39629248-4fa6-47b8-83c7-745a7efea259)\1.2.0.0\Crayon\Crayon.rhp “Crayon” 1.0.0.0
C:\Users\Czaja\source\repos\EtoDockableApp\EtoDockableApp\bin\Debug\net48\EtoDockableApp.rhp “EtoDockableApp” 1.0.0.0
C:\Users\Czaja\AppData\Roaming\McNeel\Rhinoceros\packages\8.0\SubstanceImporter\2.0.7\Substance.Win.rhp “SubstanceImporter” 2.0.7.0
C:\Program Files\Rhino 8\Plug-ins\Karamba\License\Karamba3D_LicensePlugin_Rhino8.rhp “Karamba3DLicense”
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.14.24317.14001
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.14.24317.14001
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.14.24317.14001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.14.24317.14001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.14.24317.14001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.14.24317.14001
Hi Jakub -
Yes, I’ve been bisecting the cause of this issue for a while now. When I find the source of the regression, I’ll put it on the list.
Note that you can run the PluginManager command to jump to a different page in that dialog. From that different page, you can change to any other page. It’s just the Render page in the Document Properties that is stuck…
Thanks,
Thanks for the tip. Your method works.
This issue is now on the list as RH-84744 DocumentProperties: Stuck on Render
I also got this.
So together with another bug, this caused me to I want to revert to the stable releases… but seems this can’t be done within Rhino? I selected “service release” from the updates menu and did a check for updates, and it says I’m on the latest version. Rhino doesn’t offer an in-app downgrade?
It doesn’t. You need to uninstall current Rhino and install from stable installer - you can redownload it from the download page.
Uninstalling Rhino does not remove your settings
