I am using the latest Rhino WIP to use Shrinkwrap on a model. I set preview to be on and set the target length quite low. At first I set it to 1 which took about 10 seconds and then to 0.3 which took a long time. Well, it actually took too long. After around 5 minutes I tried to cancel the preview of the Shrinkwrap, because it was still not done. I pressed cancel on the Shrinkwrap window and the window closed, but it now it started Shrinkwrapping again in the Command Line, which I could not cancel.
Pressing ESC did nothing.
Eventually this mysterious window opened, but neither Retry nor Switch To really did anything.
Had to force quite Rhino WIP in the end.
Shouldn’t cancelling out of the Shrinkwrap Window cancel any shrinkwrapping for preview or otherwise?
What is up with that cryptic error message?
Running Rhino 8.0.23193.6305 on Windows 11
