Hello
Why in the first case, when we block all the threads, there is no problem
But in the second case, there is a bug that increases both the file size and the processing effect
Please fix
Hello
Please fix
Hello - please post the file, I’ll take a look.
Hello - for some reason I am unable to open that rar - can you try a zip?
thanks,
Hello - the difference is, in the first case you are inside BlockEdit
and the pyramids are polysurfaces - they are deformed when they are flowed. In the second case, green, the pyramids are individual block instances and these are flowed ‘rigid’ regardless of the ‘Rigid’ setting in FlowAlongSrf
- they are not deformed. Using Rigid=Yes in the BlockEdit
case should have it behave the same as the greens.
