Hello there, pretty simple crash to setup :
- create a simple block with just a box inside
- try to insert another instance of this block from the bloc definition manager
- you can ppick a location, sometimes even a scale, but I never managed to get to the end of the process
I know the rewrite is being done currently so I wasn’t expecting a stable manager, but the block manager is really unusable right now…
EDIT : oh wow, figured out something! If I do not select the block definition but just right click on the name line, then I can insert a definition. Well, it did crash right after when I tried to select the definition in the manager. Seems like this has to do with the outline halo
