Bug: blank properties dialog box
The past few WIP have had this quirk, a randomly blank properties dialog box. If I switch the internal tabs, and/or resize the dialog box, sometimes I can get it to snap back into displaying as normal.
Did you use FullScreen by any chance?
Any specifics how to trigger this bug?
If you run into this, close and reopen by running Properties, does it come back?
Occasionally use fullscreen, not an apparent factor here. In the blank dialog state that it is in right now, closing and re-opening the Properties dialog several times has no effect. It opens blank each time.
Haven’t noticed a pattern, most of the time it works as expected.
what happens if you open another instance in the sidebar (via the + icon)
Unclear on the “+” button functioning here.
Have restored default workspace.
The way to get the properties dialog back is to click on the “Decals” sub-tab, all of the others are blank, this temporarily restores the properties function, but if I close the dialog it is blank again upon re-opening.
@nxakt pls Run WindowLayout and save the window layout, then send that to me. Hopefully that helps me to reproduce this issue.
Also run _SystemInfo and post back the results.
wait.. I can now repeat what you are getting
I think this issue surfaces with my changes to the analysis panels. A fix will be in the next BETA
RH-97131 Properties page goes blank
RH-97131 is fixed in Rhino BETA
