Bug / annoyance CurvatureGraph selections
“Select Objects” or “Select Sublayer Objects” in the layer panel selects the objects in a layer or sub-layer when used to select objects for CurvatureGraph if the objects do not have control points or edit points turned on. Any objects with control points or edit points turned on are ignored. However I can select objects with control points or edit points turned on for CurvatureDisplay by clicking directly on the object or by using a selection box.
This is a significant annoyance when I’m editing sets of curves.
Hi David- I think that is true of all the Sel* commands as well - SelCrv fails in the same way. This is not true in the current V6 in-house builds but not particularly as a fix for this, it’s just that it is possible to select top level objects that have points on in general.
