miano
(Miano)
September 25, 2021, 3:09pm
1
I believe I mentioned this in a heads up post but this sequence of steps appears to show this bug consistently for me:
Take a template with some predefined styles.
PURGE
Paste some text or dimensions with a style name that was not in the template.
The style of the pasted text shows up in the Inspection Panel:
But I get this on the project settings:
The pasted style will show up in the text and dim comments. But, if you try to select it you get:
wim
(Wim Dekeyser)
September 27, 2021, 9:11am
2
Hi -
I’m not seeing that here by following the steps that you have outlined.
Which version of Rhino are you running?
miano
(Miano)
September 27, 2021, 1:57pm
3
Version 7 (7.10.21256.17002, 2021-09-13)
miano
(Miano)
September 28, 2021, 8:59pm
4
I see a lot of bizarre behavior related to styles. Here is one I had not seen before. I was creating text and it was microscopic (unlike the other text using the same style). Then I notice this where I had to override the style while creating the text.
Restarting Rhino caused the problem to go away.
