Bug: Annotation Style Alignment Greyed when set to Horizontal to View
the result is that i can not change the setting, though when i deactivate “Horizontal to View” i can set it and then have check the marker again.
the same seems true for radial dimension below, i did not try it but it is grey so i assume the same is happening there.
Running 7.16.22067.13002, 2022-03-08
