BUG: An icon can't be edited after the initial edit
I edited the macro of this particular icon in the latest Rhino 9 BETA, adding the repeat star symbol * in front of the main command. Once I did that, holding the Shift key no longer triggers the editing of the icon. It lets me edit only the rest icons.
on the list as RH-97040 Button: edit button goes missing
Not sure if the bug is same as the one from the video from your link. My bug report is about the inability to edit a previously edited icon. Upon holding the Shift key the expected mouse tooltip consisting the “Edit” and “Move” options will not show up.
yes that’s what I’ve been seeing, There is an edit button at first, but it disappears
Yep, me too here. I created a new button, put a command, edited it once and now can’t edit it anymore. As the right click functions don’t work on the button, I can’t drag it off the toolbar to delete it either.
Just getting this with a Ctrl or Shift+ right click on the button (it doesn’t have a right click command)
Clicking on the “Edit button” menu entry gets me this:
I’m unable to edit the RMB command of the “Save” icon of the latest Rhino 9 BETA (9.0.26225.6303, 2026-08-13).
When I replace both, the “Command” (! _SaveAs) and the “Name”, “Button”, "Menu and “Tooltip” (Save as…) and hit OK, the mouse tooltip remains unchanged (set as “Export selected objects” by default) and asks me to select objects to export instead of saving as…
Was this resolved by the latest build @Rhino_Bulgaria ?
Seems like it works properly now. I just rested it. Thanks!
