Conversion from letters to integers produces Null-values, as one would expect - except for the letter E, which is translated to 3. In my logic, the letter E should also produce Null values.
Scientific notation using the letter E works correctly, as far as I know.
I’m pretty sure that’s the mathematical constant e (i.e. being rounded/cast to an integer):
Ok, this explains the behaviour… It is interpreted as Euler’s number.
Yep, I reached to the same conclusion.
I have to construct a more robust method for identifying alphabetical characters in alphanumerical codes then…
The Python string class has several methods for identifying what the string represents (e.g. isalpha
, isnumeric
, and isAlnum
) that might be handy here. Regular expressions are also great for these types of problems. You can implement the standard re
Python module for this.
I opted for isalpha.
Small, clean and simple.
