BUG: "Align to control polygon" mode is not reliable
There is one very confusing aspect of the “Align to control polygon” mode of Gumball. When I select a single control point which is visible, the mode works as expected.
However, if the control point is obscured from the view ever so slightly, window-selecting it converts the Gumball orientation to “Align to Cplane” mode, despite that technically speaking it remains in “Align to control polygon” mode.
The expectation is that when the user selects just one or a few control points (no other type of objects), the “Align to control polygon” mode should align to the control polygon - as the name implies.
yeah that seems quite confusing. —Mark
This HUGE BUG is still not resolved in the latest BETA. Extremely irritating while working with control points as I’m forced to constantly check the alignment of the Gumball while in “Align to Control polygon” mode…
Hi @Rhino_Bulgaria,
I’ve logged a ticket so a developer can investigate.
– Dale
Thank you for the quick reaction, @dale ! Perhaps it’s something related to the Z-buffer. Window-selecting through fully or partially transparent geometry (while in Wireframe or Ghosted display mode) is not an issue, but becomes a huge issue when the geometry is solid.
RH-99364 is fixed in Rhino BETA
