Buckling simulator in Karamba
Hi, im trying the buckling 3D Concrete printing, my render model shows how the line is touching because of the noozle diametre, but i dont know if it is considered in the simulation with the cross section, because im working with shell.
Thank you in advance :slight_smile:
@karamba3d
this is not considered, if you wish to connect it, then you need to model the connection
something like this?
yes, but make sure that your mesh vertices actually touch too.
and how can I check that??
if you are using meshes, then check that the mesh vertices are the same
thank u so much, I have another question, is it possible to simulate more complex geometries like open breps or meshes from the beginning? Because it gives me an error If I do not use geometries that are untrimmed surfaces at the loft step and it limitates me the final design.
