Broken Edges
Hello.
After moving my file to a different location, some object’s edges started to disintegrate. The edges start to flow towards infinity and are not clickable if that makes any sense. I am pretty lost, help ist very much appreciated.
best, Oscar
How far is the object from the world origin?
It is very difficult to diagnose a problem without a .3dm file with the geometry. You can upload a file by clicking on the vertical arrow icon above where you type a post.
Hi David, attached please find the .3dm of the problem TEST.3dm (12.6 MB)
there is nothing wrong with the file you have posted, did you move your objects after this file? if so then you would have to upload the file where the issues start. as david suggests it is highly likely that you placed your object very far from the origin which leads to such problems as you describe.
Hi Oscar -
I would say that these symptoms point to issues with your GPU. Does your machine meet the minimum requirements as on Rhino - System Requirements? If so, please run the Rhino SystemInfo command and copy-paste the result here.
from what i have seen is that mac does actually not suffer from such driver issues like Rhino for windows.
