Hello there,
I am facing a problem where lines are not being displayed correctly. The issue concerns dashed lines in the top view. Depending on the zoom factor, either small dashed lines or larger ones are displayed. Please note my screen recording:
my system: Apple M2 Max MacOS Sonoma 14.2.1 (23C71); Rhino 8 8.3
wim
(Wim Dekeyser)
January 18, 2024, 3:45pm
2
Hi Michael -
Could you please provide both a simple 3dm file that shows this behavior and the output of the Rhino SystemInfo
command?
Could not recreate the bug today with the same file. Can’t provide the file because of confidentiality. System info:
Apple macOS Version 14.3 (Build 23D56) (Physical RAM: 64Gb)
Mac Model Identifier: Mac14,6
Language: de-DE (MacOS default)
.NET 7.0.0
Metal GPU Family Apple 7
Metal GPU Family Common 3
Metal GPU Family Mac 2
Graphics processors
Apple M2 Max
X27 Fusion (2560 x 1440 @ 60.00Hz)
Color LCD (1728 x 1117 @ 120.00Hz)
HP E24 G4 (1080 x 1920 @ 60.00Hz)
USB devices
None
Bluetooth devices
None
Third party kernel extensions
None
Third party plugins
/usr/lib/usd/libusd_ms.dylib
/usr/lib/swift/libswiftCoreML.dylib
/usr/lib/swift/libswiftFileProvider.dylib
/usr/lib/swift/libswiftGLKit.dylib
/usr/lib/swift/libswiftGameplayKit.dylib
/usr/lib/swift/libswiftMetalKit.dylib
/usr/lib/swift/libswiftModelIO.dylib
/usr/lib/swift/libswiftSceneKit.dylib
/usr/lib/swift/libswiftSpriteKit.dylib
/usr/lib/swift/libswiftVision.dylib
/usr/lib/swift/libswiftVideoToolbox.dylib
/usr/lib/swift/libswiftObservation.dylib
/usr/lib/swift/libswiftWebKit.dylib
/usr/lib/swift/libswiftNaturalLanguage.dylib
/usr/lib/swift/libswiftMapKit.dylib
/Applications/Rhino 8.app/Contents/Frameworks/RhMaterialEditor.framework “Renderer Development Kit” 8.3.24009.1002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Commands.rhp “Commands” 8.3.24009.15002
/Applications/Rhino 8.app/Contents/PlugIns/NamedSnapshots.rhp “Snapshots” 8.3.24009.1002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCodePlugin.rhp “RhinoCodePlugin” 8.3.24009.15002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RDK_EtoUI.rhp “RDK_EtoUI” 8.3.24009.15002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/MeshCommands.rhp “MeshCommands” 8.3.24009.15002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoRenderCycles.rhp “Rhino Render” 8.3.24009.15002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCycles.rhp “RhinoCycles” 8.3.24009.15002
/Applications/Rhino 8.app/Contents/PlugIns/SectionTools.rhp “SectionTools” 8.3.24009.1002
/Applications/Rhino 8.app/Contents/PlugIns/RhinoRender.rhp “Vorgänger Rhino-Renderer” 8.3.24009.1002
/Applications/Rhino 8.app/Contents/PlugIns/Displacement.rhp “Displacement” 8.3.24009.1002
/Applications/Rhino 8.app/Contents/PlugIns/PanelingTools.rhp “PanelingTools” 8.3.24009.1002
/Applications/Rhino 8.app/Contents/PlugIns/SolidTools.rhp “Volumenkörperwerkzeuge” 8.3.24009.1002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoDLR_Python.rhp “IronPython” 8.3.24009.15002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/GrasshopperPlugin.rhp “Grasshopper” 8.3.24009.15002
