BringToFront - not selectable geometry
BringToFront is a great command when for example drawing hidden geometry in 2D for explanation reasons.
But … it also produces geometry that is not selectable albeit visible. Which is very confusing.
Isn’t it more natural if geometry that has been to brought to Front is actually selectable ?
Shouldn’t this be the default behaviour ?
Thanks
/Erik
Do you have a file that illustrates this behavior? I don’t see how something that has responded to BringToFront would not be selectable afterward.
In this file
BringToFront Example 240601.3dm (449.2 KB)
there are two boxes with a rectangle below. The left rectangle has “BringToFront” applied. The right has not.
I can’t select the rectangle brought to front.
I can select either one…
SelRect
OK, I see what you mean if I set the viewport to shaded. Don’t know what can be done there, there appears to be a conflict between selecting occluded objects and display order…
SelRect2
@mikko - can something be done here?
