BringToFront needs pick edge or line or face option
V5
Selecting the L bracket and running BringToFront doesnt see it appear in front of the image.
draw a cube and with edge ‘B’ it works, however move edge ‘B’ to where ‘A’ is and it then vanishes.
The BringToFront command is operating on the nearest edge of the L bracket, rather than the entire bracket.
we need to be able to pick the surface or edge or line that is the item of our desire.
see attached.
here is the image that goes with it. (or does the file have that embedded ?..my work is linked.
BringToFront needs edge or surface selector.3dm (99.7 KB)
Steve
Hi Steve -
As stated in the help file, the DrawOrder commands only work on annotations, hatches, details, curves, and point objects. In Rhino 9, in addition to those, picture surfaces are also supported.
I’ve added your request to RH-18266 Draw order commands should support surfaces
