Bridging Mesh Crash
I ran across this bug (crash) on a all meshes I have tried. If I run the bridge command on a mesh I get an instant crash everytime. The crash occurs even if the meshes are duplicates with matching vertices and I try to bridge between them. If I convert it to subD first, it bridges fine.
Tested:
  1. Create Cylinder
  2. Delete end surfaces
  3. Convert Cylinder surface into mesh
  4. Duplicate mesh
  5. Run Bridge command by selecting the end edges loops.
  6. Crashes the whole program. With crash report.
Version 8 (8.7.24113.23002, 2024-04-22)
System Info:
Rhino 8 SR7 2024-4-22 (Rhino 8, 8.7.24113.23002, Git hash:master @ 6d95a2bfe831b9dd0ef81b6e220b294af59416ca)
License type: Commercial, build 2024-04-22
License details: Cloud Zoo
Apple macOS Version 14.4.1 (Build 23E224) (Physical RAM: 32GB)
Mac Model Identifier: MacBookPro15,1
Language: en-US (MacOS default)
.NET 7.0.0
Metal GPU Family Apple 0
Metal GPU Family Common 3
Metal GPU Family Mac 2
Graphics processors
Intel UHD Graphics 630 (1536 MB)
Radeon Pro 560X (4 GB)
LG HDR 4K (3840 x 2160 @ 30.00Hz)
LG Ultra HD (3840 x 2160 @ 30.00Hz)
USB devices
EPSON: ET-7750 Series
Generic: OWC Thunderbolt 3 Dock SD Card Reader
SanDisk: Portable SSD
Other World Computing: OWC Thunderbolt 3 Audio Device
Apple Inc.: Touch Bar Backlight
Apple Inc.: Touch Bar Display
Apple Inc.: Apple Internal Keyboard / Trackpad
Apple: Headset
Apple Inc.: Ambient Light Sensor
Apple Inc.: FaceTime HD Camera (Built-in)
Apple Inc.: Apple T2 Controller
Bluetooth devices
None
Third party kernel extensions
com.OWC.ThunderboltDockChargingSupport (1.2) A253F2D8-14AD-3A23-9D05-88B3FE1C67D0
Third party plugins
/usr/lib/usd/libusd_ms.dylib
/usr/lib/swift/libswiftCoreML.dylib
/usr/lib/swift/libswiftFileProvider.dylib
/usr/lib/swift/libswiftGLKit.dylib
/usr/lib/swift/libswiftGameplayKit.dylib
/usr/lib/swift/libswiftMetalKit.dylib
/usr/lib/swift/libswiftModelIO.dylib
/usr/lib/swift/libswiftSceneKit.dylib
/usr/lib/swift/libswiftSpriteKit.dylib
/usr/lib/swift/libswiftVision.dylib
/usr/lib/swift/libswiftShazamKit.dylib
/usr/lib/swift/libswiftObservation.dylib
/usr/lib/swift/libswiftVideoToolbox.dylib
/usr/lib/swift/libswiftWebKit.dylib
/usr/lib/swift/libswiftNaturalLanguage.dylib
/usr/lib/swift/libswiftMapKit.dylib
/Applications/Rhino 8.app/Contents/Frameworks/RhMaterialEditor.framework “Renderer Development Kit” 8.7.24113.1002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Commands.rhp “Commands” 8.7.24113.23002
/Applications/Rhino 8.app/Contents/PlugIns/NamedSnapshots.rhp “Snapshots” 8.7.24113.1002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCodePlugin.rhp “RhinoCodePlugin” 8.7.24113.23002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RDK_EtoUI.rhp “RDK_EtoUI” 8.7.24113.23002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/MeshCommands.rhp “MeshCommands” 8.7.24113.23002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoRenderCycles.rhp “Rhino Render” 8.7.24113.23002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCycles.rhp “RhinoCycles” 8.7.24113.23002
/Applications/Rhino 8.app/Contents/PlugIns/SectionTools.rhp “SectionTools” 8.7.24113.1002
/Applications/Rhino 8.app/Contents/PlugIns/Displacement.rhp “Displacement” 8.7.24113.1002
/Applications/Rhino 8.app/Contents/PlugIns/PanelingTools.rhp “PanelingTools” 8.7.24113.1002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoDLR_Python.rhp “IronPython” 8.7.24113.23002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/GrasshopperPlugin.rhp “Grasshopper” 8.7.24113.23002
Hi Jason - thanks for the report, I’ll check it.
@jason like this, correct?
-Pascalk
@pascal Yes, I’m having this issue on all meshes that I try to bridge. This example on just a simple cylinder mesh. As a work around i’ve just tried to remember to subd them to get to work. When I forget, I lose my progress. I have been editing more complex meshes that I need to bridge, this is just an example of the operation.
Hi Jason - got it thanks - this blows up on Mac.
RH-81749 Bridge - crash on Mac
